Cleaning, lubricating and centering a Zeiss GFL Pol Scope
  • Hi Bernd,
    here is a picture of the 2.5x objective
    The cylinder containing the front optics A is locked to the cone B also with the screw C removed.
    By holding firmly the ring G the cone and the cylinder rotate up to about 120° relative to F when a strong rotatory force is applied to the ring D.
    The ring F rotates freely with respect to te objective body H, An eccentric movement of the other side of the optics containing cylinder is detectable.
    From the english reference the cone should unscrew easily, but is not my case, so I concluded that two things can happen:
    1) The limited rotation is due to some hardened grease on the cone threads.
    2) While rotating, the optics cilinder and some other parts bound to it moves downwards and encounters a stop.
    I hope to have been clear.
    Regards,
    Salvatore
  • Thank you very much for this possibility!
    I will probably profit of it when I will finish the tests on the scope.
    Regards,
    Salvatore
  • Hi Bernd,
    I prepared and observed some melt crystallized specimen to test the scope performance.
    I saw that the 2.5x, 6.5x and 16x objectives show a field of view slightly off centered with respect to the rotation axis of the table, but if a crystal is placed in the center of the field, it stays always in the field while the table is rotated.
    It is not the best situation, but it allows some use as a qualitative tool, which is my main utilization.
    The 40x objective was badly off center, but a few drops of Zippo fuel allowed some movement of the rings and a sufficient centering.
    Finally, the 100x, which I use very seldom, was incompletely frozen, but with the same treatment showed a very smooth rotaion of both rings allowing a good centering.
    With time the benefits of the treatment with the fuel will disappear and the objectives will again freeze, but I hope they will keep the partially centered situation.
    However I stll try to give me an answer to a main question:
    If the conical end part of the objectives has the threads frozen, but the rings rotate freely, there is no way to block the centering cylinder to force the unscrewing, even in case of slight thread freezing.
    Thank you for the kind attention given to my efforts.
    Regards,
    Salvatore
  • Hi Bernd,
    I am sorry, I should have said: "I do not see any way..."
    In fact, I thought to block one centering ring by a tool that could enter in the back and fit on the two horizontal diametrally placed holes, visible also in the photographs f dismounted objectives, but since it needs a particular tool I postponed this approach to the future.
    Regards,
    Salvatore
  • Hi Bernd,
    I am quite ashamed to disturb you after so long time and still bound to the same problem: the lubrication and alignment of my Zeiss GFL Pol.
    At the end of the long efforts I obtained a partially centered rotating table and a completely uncentered illumination system, and left the scope as such, involved in many family problems.
    Now I am giving another look to the scope and since I have no need to perform quantitative measurements I give more importance to the centering of the illumination.
    So I tried to implement tha so called Koehler illumination.
    As I understand it consists in adjusting the condenser in a way to have an image of the field diaphragm in the plane of the specimen, and an image of the lamp filament on the at the plane of the aperture diaphragm.
    I got easy the first condition, but since there is a fixed ground glass filter after the lamp I have no way to adjust the distance between the lamp and the condenser.
    I am very surprised that Zeiss has such an illuminating set up.
    Given this situation I proceeded in this way:
    I mounted a common not centrable objective and moved the condenser group up to a good focused image of the field diaphragm, then centering it by means of the two screws.
    At this point I replaced the fixed objective with a centerable one, and try its centering.
    Before proceeding with the help of a solvent and mild heating to reach this result (and then let it freeze forever) I like to know which are the safe solvents to use (that do not provoke delamination of the objective lenses).
    I consider benzin, gasoline, xilol, aceton, spray unblocker and lubricant, ethyl alcohol.
    While thanking you for your attention and excusing me for being unable to participate to the blog (but work is in progress), I hope for you an year full of good news.
    Best regards,
    Salvatore
    Hallo Salvatore,
    schön mal wieder was von dir zu hören nach so langer Zeit.
    Was die Wartung der Pol-Objektive anbetrifft, gibt es dieses Faden. Vielleicht hilft er dir als Anleitung.
    RE: Zeiss Pol-Objektive in der Wartung.
    Die Verharzungen werden mit Benzin gereinigt und ggf. mit Kriechöl vorbehandelt, welches nach der Demontage zu entfernen ist.
    Da sich das Mattglas vor dem Lampenkollektor in der Tat nicht wegschwenken läßt, kann man sich aber durch eine passgenaue Lochblende behelfen, die in die Kollektorfassung gesteckt wird. Dadurch läßt sich der Strahlengang ohne Objektiv und Kondensor bereits recht gut zentrieren. Wenn nach dem geköhlerten Zustand mit Objektiv und Kondensor das Kollektorzentrum außerhalb der optischen Achse liegt, ist vermutlich die Frontoptik des Kondensors dejustiert.
    Mit Google kannst du nun das Geschriebene übersetzen lassen und deine Antwort ebenfalls übersetzen, bevor du sie postest. Dann braucht das nicht jeder Mitleser zu machen.
  • Die Verwendung einer undurchsichtigen Lochblende scheint für die Ausrichtung des Kondensors nützlich zu sein, aber ich meine jedoch die Positionierung der Lichtquelle relativ zur Aperturblende, wie empfohlen, um eine Köhler-Beleuchtung zu erreichen
    Das Vorhandensein einer Mattscheibe in einer festen Position zwingt mich dazu, mich zwischen der Fokussierung der Feldblende in der Ebene der Probe und der Fokussierung der Mattscheibe in der Ebene der Aperturblende zu entscheiden. Es ist nicht möglich, beide Bedingungen zu erfüllen.
    Code
    Entschuldigung mein Deutsch.
    Salvatore
    Da hast du recht, bei den größeren Lampenhäusern hat man die Möglichkeit, die Streuscheibe vor dem Kollektor wegzuschwenken, um die Lampenwendel zentrieren zu können. Die Lampenfassung vom Leuchtrohr bietet aber keine Zentriermöglichkeit. Dafür sind die Lampensockel mit einem gewissen Blechkranz versehen, der gegenüber dem normalen Lampensockel für eine bessere Zentrierung und Positionierung sorgt. So ist die Kollektorlinse vor der Lampe mattiert.
  • A few days ago I started working on the plan 2.5x Pol lens again.
    I splashed a little Pinlube on the centering rings and verified that the behavior of the lens was similar to what was described in my 2019 messages, with the possibility of rotating one ring 120° with respect to the other, albeit with a little ' of effort.
    After a few days, however, I had the unpleasant surprise of finding the two rings completely locked together, but very free to rotate with respect to the lens body, much more than before.
    From that moment on I tried in vain to move the rings together, despite repeated treatments with the solvent, heating with the hairdryer and strong twisting on the rings.
    The two rings are so blocked that I thought of a mechanical impediment, for example a second fixing screw, even if I don't understand why they had the possibility to rotate a little before.
    What to do? To understand a little more I studied a drawing taken from a Zeiss publication showing a 100x Pol lens and I attributed their function to the various parts in section, to make a mental model of Zeiss Pol lenses, which I believe are similar in mechanism centering, apart from the sprung optics for the 50x and 100x.
    I am sending you the drawing with a request to verify whether my attribution is correct.
    Accepting its correctness, it seems that the outer centering cylinder slides almost without resistance, while the rest forms a blockage.
    What can I do? Your every suggestion will be invaluable.
    I take this opportunity to wish you a Happy Easter.
    Salvatore
  • Excuse but I do no know how to place r the german version.
    Here is it:
    Vor ein paar Tagen habe ich wieder angefangen, an dem 2,5x Pol-Objektiv zu arbeiten.
    Ich habe ein wenig Pinlube auf die Zentrierringe gespritzt und festgestellt, dass das Verhalten des Objektivs dem in meinen Nachrichten von 2019 beschriebenen ähnelt, mit der Möglichkeit, einen Ring um 120° gegenüber dem anderen zu drehen, wenn auch mit etwas Aufwand .
    Nach ein paar Tagen erlebte ich jedoch die unangenehme Überraschung, dass die beiden Ringe vollständig miteinander verbunden waren, sich aber sehr viel freier im Verhältnis zum Objektivkörper drehen ließen, viel mehr als zuvor.
    Von diesem Moment an versuchte ich vergeblich, die Ringe zusammenzubewegen, trotz mehrmaliger Behandlung mit dem Lösungsmittel, Erhitzen mit dem Fön und starkem Verdrehen der Ringe.
    Die beiden Ringe sind so blockiert, dass ich an ein mechanisches Hindernis, zum Beispiel eine zweite Befestigungsschraube, gedacht habe, auch wenn ich nicht verstehe, warum sie vorher die Möglichkeit hatten, sich etwas zu drehen.
    Was zu tun? Um etwas mehr zu verstehen, habe ich eine Zeichnung aus einer Zeiss-Publikation studiert, die ein 100-fach-Pol-Objektiv zeigt, und ihre Funktion den verschiedenen Teilen im Schnitt zugeordnet, um ein mentales Modell von Zeiss-Pol-Objektiven zu erstellen, die meiner Meinung nach hinsichtlich der Mechanismuszentrierung ähnlich sind. abgesehen von der gefederten Optik für das 50x und 100x.
    Ich sende Ihnen die Zeichnung mit der Bitte, zu überprüfen, ob meine Namensnennung korrekt ist.
    Akzeptiert man die Richtigkeit, so scheint es, dass der äußere Zentrierzylinder nahezu ohne Widerstand gleitet, während der Rest eine Blockade bildet.
    Was kann ich machen? Jeder Ihrer Vorschläge wird von unschätzbarem Wert sein.
    Ich nutze diese Gelegenheit, um Ihnen frohe Ostern zu wünschen.
    Salvatore
    • Neu
    Hallo Salvatore,
    dann machen wir mal extra für dich nochmal das Plan 2,5 -Pol.
    Das Plan 2,5-Pol-Objektiv hat in Gegensatz zu deinem 100er Pol-Objektiv in deiner Werksabbildung keine gefederte Optik, da der Arbeitsabstand bei diesem Objektiv um einiges größer ist.
    Und dennoch ist es bei diesem Objektiv leider erforderlich, den Linsensatz auszubauen, bevor man die Fassung weiter zerlegen kann. Bei den gefederten Objektiven ist der Linsensatz in einem separaten Zylinder und müssen nicht zwangsweise ausgebaut werden.
    Bevor die Fassung nun weiter zerlegt werden kann, müssen die beiden Stellringe abgeschraubt werden. Dazu müssen die vorab die sichernden Madenschrauben entfernt werden, da es sonst zu einem Schaden kommen würde.
    Man sieht hier schon die Einzelteile der Fassung, links das Gehäuse, ganz rechts der äußere Zylinder, daneben der innere Zylinder. Sie sind ineinander gesteckt und lassen sich alle im Idealfall frei zueinander verdrehen. Wenn das nicht möglich ist, weil z.B. verharzt, muß die Verharzung beseitigt werden.
    Beim Versuch, die Stellringe abzuschrauben kann es passieren, daß sich die beiden Exzenter-Zylinder dabei mitdrehen und dazu festgehalten werden müssen. Möglich wird das durch einen kleinen Bolzen, den man von Innen in die Querbohrungen der Zylinder stecken kann. Erst dann kann der Vorschraubring entfernt werden, der durch den äußeren Stellring verdeckt wird.
    Man muß auf jeden Fall mit Bedacht vorgehen. Zu viel Gewalt kann dazu führen, daß dich die Hülsen verziehen oder gar beschädigt werden, daß man sie nach dem Wiederzusammenbau nicht mehr leicht gegeneinander verstellen kann, weil dabei irgendetwas bremst oder gar blockiert. Von der Wärmebehandlung ist auf jeden Fall abzuraten, insbesondere, wenn die Optik noch eingebaut ist.
    Nun hoffen wir mal, daß du deine Verklebung mit Pinlube wieder gelöst bekommst. Das war wohl ein wenig kontraproduktiv, sowas einzusetzen.
  • Hi Bernd,
    I uploaded one of your images with their attribution, to be compared with the objective section uploaded before.
    I will message again when I will have time, for the moment thanks for the attention and good Easters!
    Salvatore
  • Please be patient and hear some considerations.
    I could dismount the screw in cap and the ring nut, as well as the grub screws on the centeing rings.
    Under such a situation, with all the body of the objective is rotating with no friction relatively to the objective tube (at the extreme left in the image) I think that the following actions ca be attempted, both with some risk.
    1) Float for 24 hours or so the whole objective in a solvent, like petrol or other hydrocarbons, hoping that it does not dissolve the adhesive of the lenses. (by he way, in order to fill a delaminated portion of a doublet in an ocular someone has treated it with xilene and aceton for days, without noxious effects on the lens optics,)
    2) Apply a strong torque to the centering rings, confident on the former behaviour when the rings had some play each other.
    I do not see other possibilities.
    By the way, after so many trials the old grease should have been washed out (this is why the external cylinder rotates frictionless) and I do not see between which parts could seizing occur.
    In short, if you had such a problem, which will be your next move)
    Grateful for any suggestion,
    Salvatore
    • Neu
    Sie können von mir aus das Objektiv in Lösemittel einlegen, sofern es nicht den äußeren Lack angreift oder gar ablöst. Aber wenn Sie den Linsensatz nicht vorher herausdrücken, wird mit hoher Wahrscheinlichkeit das Lösemittel zwischen die Linsen gelangen. Auch wenn es die Verkittung nicht angreift, wird das Bild schlecht oder gar unbrauchbar sein, so lange Lösungsmittel noch im Zwischenraum steckt. Ähnliches Problem wie bei Immersionsobjektiven, bei denen Öl durch zu viel Ölauftrag und Kapilarwirkung eingedrungen ist.
  • Many thanks for the answer, but before continuing please tell me how I can publish both the english and the german version of my messages.
    I can also publish the german version alone, given the public to which the forum is directed.
    Salvatore
